Dell XPS 10 Battery Replacement
  1. Dell XPS 10 Battery Replacement, Battery: step 1, image 1 of 3 Dell XPS 10 Battery Replacement, Battery: step 1, image 2 of 3 Dell XPS 10 Battery Replacement, Battery: step 1, image 3 of 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: step 2, image 1 of 3 Dell XPS 10 Battery Replacement: step 2, image 2 of 3 Dell XPS 10 Battery Replacement: step 2, image 3 of 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
2 other people completed this guide.
saraspam
244 Reputation
2 Guides authored
USF Tampa, Team 2-1, Nance Fall 2016 Member of USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 3,138
