Dell XPS 10 Front and Rear Camera Replacement
  1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 1 of 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 2 of 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 3 of 3
    • Unscrew the two screws shown circled in red in the picture.
    • Use a #0 Phillips screwdriver to remove the two 4 mm screws
    • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
  2. Dell XPS 10 Front and Rear Camera Replacement: step 2, image 1 of 2 Dell XPS 10 Front and Rear Camera Replacement: step 2, image 2 of 2
    • After the rear facing camera is removed, you may now remove the front facing camera.
    • Use the nylon spudger to disconnect the cable on the motherboard.
    • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
James
401 Reputation
3 Guides authored
USF Tampa, Team 2-1, Nance Fall 2016 Member of USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 332
