Dell XPS 12 9Q23 Battery Replacement
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: step 1, image 1 of 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: step 2, image 1 of 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: step 3, image 1 of 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: step 5, image 1 of 1
    • Once all the screws have been removed the battery is now safe to extract
5 other people completed this guide.
2 Comments
Any tips for registering the new battery in the BIOS?
Ryan Porter - Reply
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 44
All Time: 4,415
