Dell XPS 12 9Q23 Touch Pad Replacement
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: step 1, image 1 of 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: step 2, image 1 of 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: step 3, image 1 of 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: step 5, image 1 of 1
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: step 6, image 1 of 1
    • Unplug the trackpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: step 7, image 1 of 1
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the 4 trackpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: step 9, image 1 of 1
    • Remove the trackpad.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,638
