Dell XPS 12 9Q33 Back Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Dell XPS 12 9Q33 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Back Cover Replacement: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Back Cover Replacement: step 3, image 1 of 1
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
Arthur Shi
258,910 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,074 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 17
