Dell XPS 13 9310 Lower Case Replacement
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: step 1, image 1 of 2 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: step 1, image 2 of 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: step 2, image 1 of 2 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: step 2, image 2 of 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: step 3, image 1 of 2 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: step 3, image 2 of 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: step 4, image 1 of 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: step 4, image 2 of 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: step 4, image 3 of 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: step 5, image 1 of 3 Dell XPS 13 9310 Lower Case Replacement: step 5, image 2 of 3 Dell XPS 13 9310 Lower Case Replacement: step 5, image 3 of 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
2 other people completed this guide.
Spencer Day
61,613 Reputation
445 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,086 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 132
All Time: 1,571
