Dell XPS 13 9365 2-in-1 Battery Replacement
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: step 1, image 1 of 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement: step 2, image 1 of 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement: step 3, image 1 of 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Battery Replacement: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Battery Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Battery Replacement: step 7, image 1 of 1
    • Lift the battery off the palm-rest assembly.
17 other people completed this guide.
Johnathan Hammond
45,034 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 135
All Time: 14,155
