Dell XPS 13 9365 2-in-1 Speakers Replacement
  1. Dell XPS 13 9365 2-in-1 Speakers Replacement, Battery: step 1, image 1 of 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 2, image 1 of 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 3, image 1 of 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 4, image 1 of 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 7, image 1 of 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Speakers Replacement, Speakers: step 8, image 1 of 1
    • Peel off the tape securing the speaker cable to the system board.
  9. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 9, image 1 of 1
    • Disconnect the speaker cable from the motherboard.
  10. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 10, image 1 of 1
    • Note the speaker-cable routing and peel off the tape that secures the speaker cable to the system board.
  11. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 11, image 1 of 2 Dell XPS 13 9365 2-in-1 Speakers Replacement: step 11, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws (M2x2) that secure the speakers to the palm-rest assembly.
  12. Dell XPS 13 9365 2-in-1 Speakers Replacement: step 12, image 1 of 1
    • Lift the speakers, along with its cables, off the palm-rest assembly.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 546
