Dell XPS 14 L401X Mini Card Replacement
  1. Dell XPS 14 L401X Mini Card Replacement, Battery: step 1, image 1 of 2 Dell XPS 14 L401X Mini Card Replacement, Battery: step 1, image 2 of 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 1 of 3 Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 2 of 3 Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 3 of 3
    • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
    • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
    • The captive screw will not come off of the panel.
    • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
  3. Dell XPS 14 L401X Mini Card Replacement: step 3, image 1 of 3 Dell XPS 14 L401X Mini Card Replacement: step 3, image 2 of 3 Dell XPS 14 L401X Mini Card Replacement: step 3, image 3 of 3
    • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
    • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
    • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
  4. Dell XPS 14 L401X Mini Card Replacement: step 4, image 1 of 2 Dell XPS 14 L401X Mini Card Replacement: step 4, image 2 of 2
    • Remove the mini card as it flips upward.
Mark
643 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 298
