Dell XPS 14 RAM Replacement
  1. Dell XPS 14 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 RAM Replacement: step 2, image 1 of 3 Dell XPS 14 RAM Replacement: step 2, image 2 of 3 Dell XPS 14 RAM Replacement: step 2, image 3 of 3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 RAM Replacement: step 3, image 1 of 2 Dell XPS 14 RAM Replacement: step 3, image 2 of 2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 RAM Replacement: step 4, image 1 of 3 Dell XPS 14 RAM Replacement: step 4, image 2 of 3 Dell XPS 14 RAM Replacement: step 4, image 3 of 3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 RAM Replacement, Speaker: step 5, image 1 of 2 Dell XPS 14 RAM Replacement, Speaker: step 5, image 2 of 2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 RAM Replacement: step 6, image 1 of 2 Dell XPS 14 RAM Replacement: step 6, image 2 of 2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 RAM Replacement, Battery: step 7, image 1 of 1
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 RAM Replacement: step 8, image 1 of 3 Dell XPS 14 RAM Replacement: step 8, image 2 of 3 Dell XPS 14 RAM Replacement: step 8, image 3 of 3
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 RAM Replacement, RAM: step 9, image 1 of 3 Dell XPS 14 RAM Replacement, RAM: step 9, image 2 of 3 Dell XPS 14 RAM Replacement, RAM: step 9, image 3 of 3
    • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
    • Push the two metal latches on either side of the RAM outward.
    • The cartridge will pop out of the laptop.
  10. Dell XPS 14 RAM Replacement: step 10, image 1 of 2 Dell XPS 14 RAM Replacement: step 10, image 2 of 2
    • Slide the RAM cartridge out of its slot.
Gabriella Monico
457 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 541
