Dell XPS 14Z L412Z Fan Replacement
  1. Dell XPS 14Z L412Z  Fan Replacement, Back Panel: step 1, image 1 of 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z  Fan Replacement: step 2, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: step 3, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • The fan is located on the upper right hand side of the laptop.
    • Unscrew the four 4.5mm Phillips #0 screws along the fan.
  4. Dell XPS 14Z L412Z  Fan Replacement: step 4, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the fan connection by using the metal tweezers.
    • Then, plug in the new or cleaned fan back into the connection.
Cole Hanson
141 Reputation
1 Guide authored
UW Stout, Team S8-G3, Ogden Spring 2018 Member of UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 721
