Dell XPS 14Z L412Z Battery Replacement
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: step 2, image 1 of 2 Dell XPS 14Z L412Z Battery Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: step 3, image 1 of 1
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: step 4, image 1 of 1
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: step 5, image 1 of 2 Dell XPS 14Z L412Z Battery Replacement: step 5, image 2 of 2
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
4 other people completed this guide.
Colton Niewolny
411 Reputation
4 Guides authored
UW Stout, Team S8-G3, Ogden Spring 2018 Member of UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Members
6 Guides authored
One Comment
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 2,947
