Dell XPS 14Z L412Z Hard Drive Replacement
  1. Dell XPS 14Z L412Z Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Hard Drive Replacement: step 2, image 1 of 2 Dell XPS 14Z L412Z Hard Drive Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  4. Dell XPS 14Z L412Z Hard Drive Replacement: step 4, image 1 of 1
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  5. Dell XPS 14Z L412Z Hard Drive Replacement: step 5, image 1 of 1
    • Carefully pull and remove the old hard drive.
Colton Niewolny
411 Reputation
4 Guides authored
UW Stout, Team S8-G3, Ogden Spring 2018 Member of UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Members
6 Guides authored
One Comment
On my laptop there was a small curved metal bracket that sat in the very corner of the PC covering one corner of the hard drive. That had to be removed by loosening a screw and gently prying the bar out before the hard drive could be removed.
dude - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,576
