Dell XPS 15 9500 Fan Replacement
  1. Dell XPS 15 9500 Fan Replacement, Base Panel: step 1, image 1 of 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Fan Replacement: step 2, image 1 of 2 Dell XPS 15 9500 Fan Replacement: step 2, image 2 of 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Fan Replacement, Fan: step 3, image 1 of 2 Dell XPS 15 9500 Fan Replacement, Fan: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws screws from each fan (four screws total).
  4. Dell XPS 15 9500 Fan Replacement: step 4, image 1 of 1
    • Use an opening tool to push the left fan cable plug out of its socket.
    • Repeat for right fan cable.
  5. Dell XPS 15 9500 Fan Replacement: step 5, image 1 of 1
    • Lift the fan up and away from the heatsink.
    • Repeat for the right fan.
Bryan Chung
437 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 55
All Time: 1,562
