Dell XPS 15 9500 Speaker Replacement
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: step 1, image 1 of 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: step 2, image 1 of 2 Dell XPS 15 9500 Speaker Replacement: step 2, image 2 of 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: step 4, image 1 of 2 Dell XPS 15 9500 Speaker Replacement: step 4, image 2 of 2
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Bryan Chung
437 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 899
