Dell XPS 15 9510 Rear Panel Replacement
  1. Dell XPS 15 9510 Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Rear Panel Replacement: step 2, image 1 of 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Rear Panel Replacement: step 3, image 1 of 1
    • Lift the back panel of the laptop off and set it aside.
Joseph Remondi
278 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 48
All Time: 1,170
