Dell XPS 15 9530 Base-Cover Assembly Replacement
William Daniels
William Daniels and 4 other contributors
Last updated on June 26, 2024
2 - 6 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
How to remove/replace the Dell XPS 15 9530's Base-Cover Assembly (bottom panel) so that the laptop's components can be accessed.
The information and pictures in this guide have been taken from the service manual from this device, listed on the product page. If you need any additional information on disassembling this device, please consult the service manual.
Tools
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell XPS 15 9530 Base-Cover Assembly Replacement, Unscrewing the Base-Cover Assembly: step 1, image 1 of 1
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Base-Cover Assembly Replacement, Prying Off the Base-Cover Assembly: step 2, image 1 of 1
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
William Daniels
824 Reputation
6 Guides authored
2 Comments
I need to replace these screws. What is the size, dimension, type?
Jason Benci - Reply
There is no "system badge" which folds open on my Dell XPS 15 9530 (2023). It is solid aluminum, and has "XPS" stamped into it. The images published for this repair guide appear as if the bottom cover is made of some kind of plastic? Am I looking at the wrong repair guide?
Tom Farrell - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 621
