Dell XPS 15 9530 Battery Replacement
Johnathan Hammond
Johnathan Hammond and 5 other contributors
Last updated on June 26, 2024
3 - 6 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
How to replace the battery of a Dell XPS 15 9530.
Tools
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell XPS 15 9530 Battery Replacement, Unscrewing the Base-Cover Assembly: step 1, image 1 of 1
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Battery Replacement, Prying Off the Base-Cover Assembly: step 2, image 1 of 1
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
  3. Dell XPS 15 9530 Battery Replacement, Remove Battery: step 3, image 1 of 1
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery off the palm-rest assembly.
    • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
5 other people completed this guide.
Johnathan Hammond
45,210 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 3,699
