Dell XPS 15 9530 Fan Replacement
  1. Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 1 of 3 Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 2 of 3 Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 3 of 3
    • Turn the laptop upside down.
    • Unscrew ten 3 mm screws on the back cover with a Torx T5 screwdriver.
    • Remove two more 3 mm screws with a Phillips #0 screwdriver.
  2. Dell XPS 15 9530 Fan Replacement: step 2, image 1 of 2 Dell XPS 15 9530 Fan Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to unscrew the three screws on each fan.
  3. Dell XPS 15 9530 Fan Replacement: step 3, image 1 of 2 Dell XPS 15 9530 Fan Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use metal tweezers to carefully unplug the fan cables from the motherboard.
  4. Dell XPS 15 9530 Fan Replacement: step 4, image 1 of 1
    • Remove the fans by gently lifting up the edges until the fans disconnect from the motherboard completely.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,168
