Dell XPS 15 9530 Touch Pad Replacement
  1. Dell XPS 15 9530 Touch Pad Replacement, Battery: step 1, image 1 of 2 Dell XPS 15 9530 Touch Pad Replacement, Battery: step 1, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  2. Dell XPS 15 9530 Touch Pad Replacement: step 2, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  3. Dell XPS 15 9530 Touch Pad Replacement: step 3, image 1 of 1
    • Lift the battery off the chassis.
  4. Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: step 4, image 1 of 3 Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: step 4, image 2 of 3 Dell XPS 15 9530 Touch Pad Replacement, Touch Pad: step 4, image 3 of 3
    • Remove the touch pad ribbon cable by lifting the small plastic flap and pulling ribbon straight out of the connector.
  5. Dell XPS 15 9530 Touch Pad Replacement: step 5, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the four 3mm screws holding in the touchpad assembly.
  6. Dell XPS 15 9530 Touch Pad Replacement: step 6, image 1 of 3 Dell XPS 15 9530 Touch Pad Replacement: step 6, image 2 of 3 Dell XPS 15 9530 Touch Pad Replacement: step 6, image 3 of 3
    • Lift the bottom of the touchpad and pull directly out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 29
All Time: 5,872
