Dell XPS 15 9550 Back/Underside Panel Replacement
  1. Dell XPS 15 9550 Back/Underside Panel Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Back/Underside Panel Replacement: step 2, image 1 of 2 Dell XPS 15 9550 Back/Underside Panel Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Back/Underside Panel Replacement: step 3, image 1 of 3 Dell XPS 15 9550 Back/Underside Panel Replacement: step 3, image 2 of 3 Dell XPS 15 9550 Back/Underside Panel Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
12 other people completed this guide.
Brandon Schmidt
2,120 Reputation
3 Guides authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
23 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 89
All Time: 13,299
