Dell XPS 15 9550 RAM Replacement
  1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 RAM Replacement: step 2, image 1 of 2 Dell XPS 15 9550 RAM Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 RAM Replacement: step 3, image 1 of 3 Dell XPS 15 9550 RAM Replacement: step 3, image 2 of 3 Dell XPS 15 9550 RAM Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 RAM Replacement, RAM: step 4, image 1 of 2 Dell XPS 15 9550 RAM Replacement, RAM: step 4, image 2 of 2
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
  5. Dell XPS 15 9550 RAM Replacement: step 5, image 1 of 2 Dell XPS 15 9550 RAM Replacement: step 5, image 2 of 2
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
5 other people completed this guide.
jbaseballin2
117 Reputation
1 Guide authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
23 Guides authored
One Comment
What type ram do you replace it with? Could you post a link?
twrfan - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 55
All Time: 8,636
