Dell XPS 15 9550 Solid State Drive Replacement
  1. Dell XPS 15 9550 Solid State Drive Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Solid State Drive Replacement: step 2, image 1 of 2 Dell XPS 15 9550 Solid State Drive Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Solid State Drive Replacement: step 3, image 1 of 3 Dell XPS 15 9550 Solid State Drive Replacement: step 3, image 2 of 3 Dell XPS 15 9550 Solid State Drive Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Solid State Drive Replacement, Solid State Drive: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the SSD screw.
  5. Dell XPS 15 9550 Solid State Drive Replacement: step 5, image 1 of 2 Dell XPS 15 9550 Solid State Drive Replacement: step 5, image 2 of 2
    • Gently remove the SSD.
Zach Jones
352 Reputation
2 Guides authored
IUPUI, Team 2-4, Harley Spring 2022 Member of IUPUI, Team 2-4, Harley Spring 2022
IUPUI-HARLEY-S22S2G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 38
All Time: 2,097
