Dell XPS 15 9550 Wireless Card Replacement
  1. Dell XPS 15 9550 Wireless Card Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Wireless Card Replacement: step 2, image 1 of 2 Dell XPS 15 9550 Wireless Card Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Wireless Card Replacement: step 3, image 1 of 3 Dell XPS 15 9550 Wireless Card Replacement: step 3, image 2 of 3 Dell XPS 15 9550 Wireless Card Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
    • With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • Set the screw and metal holder aside.
  5. Dell XPS 15 9550 Wireless Card Replacement: step 5, image 1 of 2 Dell XPS 15 9550 Wireless Card Replacement: step 5, image 2 of 2
    • Gently lift up each of the antennas (3) to disconnect them from the wireless card.
    • These are similar to a coat button, the antennas snap on and snap off.
  6. Dell XPS 15 9550 Wireless Card Replacement: step 6, image 1 of 3 Dell XPS 15 9550 Wireless Card Replacement: step 6, image 2 of 3 Dell XPS 15 9550 Wireless Card Replacement: step 6, image 3 of 3
    • With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
    • The wireless card has been successfully removed!
4 other people completed this guide.
Hunter J Laska
157 Reputation
1 Guide authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
23 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 9,614
