Dell XPS 15 9560 Fans Replacement
  1. Dell XPS 15 9560 Fans Replacement, Back Panel: step 1, image 1 of 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Fans Replacement: step 2, image 1 of 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Fans Replacement: step 3, image 1 of 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Fans Replacement: step 4, image 1 of 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Fans Replacement, Fans: step 5, image 1 of 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  6. Dell XPS 15 9560 Fans Replacement: step 6, image 1 of 1
    • Unplug the fan cable.
  7. Dell XPS 15 9560 Fans Replacement: step 7, image 1 of 1
    • Carefully remove the left-side fan.
  8. Dell XPS 15 9560 Fans Replacement: step 8, image 1 of 1
  9. Dell XPS 15 9560 Fans Replacement: step 9, image 1 of 1
    • Remove the right-side fan.
Jada Houser
839 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 38
All Time: 2,232
