Dell XPS 15 9560 RAM Replacement
  1. Dell XPS 15 9560 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 RAM Replacement: step 2, image 1 of 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 RAM Replacement: step 3, image 1 of 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 RAM Replacement: step 4, image 1 of 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 RAM Replacement, RAM: step 5, image 1 of 2 Dell XPS 15 9560 RAM Replacement, RAM: step 5, image 2 of 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
Jada Houser
839 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 40
All Time: 1,717
