Dell XPS 15 9560 Solid State Drive (SSD) Replacement
  1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: step 1, image 1 of 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 3, image 1 of 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 4, image 1 of 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  5. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 5, image 1 of 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  6. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 6, image 1 of 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
Frederick Rowell
175 Reputation
1 Guide authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 18
Past 30 Days: 70
All Time: 2,338
