Dell XPS 15 9570 Wireless Card Replacement
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: step 2, image 1 of 3 Dell XPS 15 9570 Wireless Card Replacement: step 2, image 2 of 3 Dell XPS 15 9570 Wireless Card Replacement: step 2, image 3 of 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: step 3, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement: step 3, image 2 of 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: step 4, image 1 of 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: step 5, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: step 6, image 1 of 1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: step 7, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement: step 7, image 2 of 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: step 8, image 1 of 1
    • Carefully remove the wireless card.
2 other people completed this guide.
Margaret Combs
516 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 37
All Time: 2,695
