Dell XPS 15 9575 Bottom Cover Replacement
  1. Dell XPS 15 9575 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 Dell XPS 15 9575 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 Dell XPS 15 9575 Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Bottom Cover Replacement: step 2, image 1 of 1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 772
