Dell XPS 15 L521X Base Cover Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell XPS 15 L521X Base Cover Replacement, Turning Off the Computer, and Opening the System Badge: step 1, image 1 of 1
    • After turning off the computer, turn over the laptop and lift up the system badge (#2).
  2. Dell XPS 15 L521X Base Cover Replacement, Unscrewing the Base Cover: step 2, image 1 of 1
    • Unscrew the six Torx screws (#1) along the base cover's edge and the two Philips screws (#2) under the system badge.
  3. Dell XPS 15 L521X Base Cover Replacement, Pry Off Base Cover: step 3, image 1 of 1
    • Snap the system badge back into place so that it can be removed along with the base cover.
    • Using the spudger (or some other prying tool), pry the base cover away from the rest of the system.
  4. Dell XPS 15 L521X Base Cover Replacement, Battery Indicator Cable Removal: step 4, image 1 of 1
    • Remove the battery indicator cable (#3) from the white connector by lifting up the connector latch (#1) pulling on the tab (#2).
    • Even if you do not plan on replacing the base cover entirely, decoupling this fragile cable will ensure that it doesn't get damaged if the base cover is moved for whatever reason.
To reassemble your device, follow these instructions in reverse order with the replacement component.
William Daniels
824 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 59
