Dell XPS 15-L502X RAM Replacement
  1. Dell XPS 15-L502X RAM Replacement, Back Panel: step 1, image 1 of 1
    • Remove the black battery bar from the computer before continuing any further operations.
    • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
  2. Dell XPS 15-L502X RAM Replacement: step 2, image 1 of 1
    • Lift up the left side of the panel.
    • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
  3. Dell XPS 15-L502X RAM Replacement, RAM: step 3, image 1 of 1
    • Locate both of the RAM slots right behind the back panel.
  4. Dell XPS 15-L502X RAM Replacement: step 4, image 1 of 1
    • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
    • Once both clips have been released, the RAM will be released at a 45 degree angle.
  5. Dell XPS 15-L502X RAM Replacement: step 5, image 1 of 1
    • Carefully grab the RAM with both hands and pull outward.
    • Repeat steps 4 & 5 to remove the second RAM.
    • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
Vishal
775 Reputation
6 Guides authored
IUPUI, Team 2-3, Baechle Fall 2015 Member of IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 25
Past 30 Days: 31
All Time: 2,178
