Dell XPS 17 9710 Battery Replacement
  1. Dell XPS 17 9710 Battery Replacement, Back Panel: step 1, image 1 of 2 Dell XPS 17 9710 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove eight 5 mm screws from the back panel using a T5 Torx screwdriver.
    • Use the opening tool to loosen the panel on all sides and then lift it from the device.
  2. Dell XPS 17 9710 Battery Replacement, Battery: step 2, image 1 of 2 Dell XPS 17 9710 Battery Replacement, Battery: step 2, image 2 of 2
    • Remove seven 3 mm screws securing the battery using a JIS #1 screwdriver.
  3. Dell XPS 17 9710 Battery Replacement: step 3, image 1 of 2 Dell XPS 17 9710 Battery Replacement: step 3, image 2 of 2
    • Use the spudger to detach the battery connector from the motherboard.
    • Gently unplug this attachment.
    • Remove the battery from the laptop.
Matthew McKeown
259 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 26
Past 30 Days: 106
All Time: 3,115
