Dell XPS 17 L702X Motherboard Replacement
Eddie
Eddie and 6 other contributors
Last updated on February 21, 2020
45 minutes
Very difficult
Introduction
Go to step 1
If the motherboard of your Dell XPS 17 L702X laptop is broken, or you are upgrading your PC’s hardware and the current motherboard doesn’t have the input/output necessary to support the new hardware, use this guide the remove and replace the motherboard.
The motherboard of a computer is a firm sheet of non-conductive material with thin layers of conductive metal printed onto the board, known as traces. These traces form circuits necessary for the electrical connections between the various components of the computer.
Before beginning, make sure to completely power off your laptop and disconnect it from any external power source.
Tools
Show more…
  1. Dell XPS 17 L702X Motherboard Replacement, Battery: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Motherboard Replacement: step 2, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 2, image 2 of 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Motherboard Replacement: step 3, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 3, image 2 of 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Motherboard Replacement, Hard Drive: step 4, image 1 of 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Motherboard Replacement: step 5, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 5, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 5, image 3 of 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Motherboard Replacement: step 6, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 6, image 2 of 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Motherboard Replacement: step 7, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 7, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 7, image 3 of 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Motherboard Replacement: step 8, image 1 of 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Motherboard Replacement: step 9, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 9, image 2 of 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Motherboard Replacement: step 10, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 10, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 10, image 3 of 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Motherboard Replacement: step 11, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 11, image 2 of 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Motherboard Replacement: step 12, image 1 of 1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Motherboard Replacement, Palm Rest: step 13, image 1 of 1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Motherboard Replacement: step 14, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 14, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 14, image 3 of 3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Motherboard Replacement: step 15, image 1 of 1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Motherboard Replacement: step 16, image 1 of 1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Motherboard Replacement: step 17, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 17, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 17, image 3 of 3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Motherboard Replacement: step 18, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 18, image 2 of 2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Motherboard Replacement: step 19, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 19, image 2 of 2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Motherboard Replacement: step 20, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 20, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 20, image 3 of 3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Motherboard Replacement: step 21, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 21, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 21, image 3 of 3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Motherboard Replacement: step 22, image 1 of 1
    • Remove the palm rest from the laptop.
  23. Dell XPS 17 L702X Motherboard Replacement, Keyboard: step 23, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement, Keyboard: step 23, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement, Keyboard: step 23, image 3 of 3
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Dell XPS 17 L702X Motherboard Replacement: step 24, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 24, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 24, image 3 of 3
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Dell XPS 17 L702X Motherboard Replacement: step 25, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 25, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 25, image 3 of 3
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Dell XPS 17 L702X Motherboard Replacement: step 26, image 1 of 1
    • Remove the keyboard from the laptop.
  27. Dell XPS 17 L702X Motherboard Replacement, Display: step 27, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement, Display: step 27, image 2 of 2
    • Close the display, and flip the laptop over so that the bottom faces upwards.
    • Remove the two 16 mm screws with a Phillips screwdriver.
  28. Dell XPS 17 L702X Motherboard Replacement: step 28, image 1 of 1
    • Gently flip over the laptop and open the back cover assembly.
  29. Dell XPS 17 L702X Motherboard Replacement: step 29, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 29, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 29, image 3 of 3
    • Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
    Be very careful! Just pulled one of the connectors off the WLAN card
    Chris Geffen - Reply
  30. Dell XPS 17 L702X Motherboard Replacement: step 30, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 30, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 30, image 3 of 3
    • Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
    • Gently pull out the WLAN card.
  31. Dell XPS 17 L702X Motherboard Replacement: step 31, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 31, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 31, image 3 of 3
    • Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
  32. Dell XPS 17 L702X Motherboard Replacement: step 32, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 32, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 32, image 3 of 3
    • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself.
    • Gently pull out the WWAN card.
  33. Dell XPS 17 L702X Motherboard Replacement: step 33, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 33, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 33, image 3 of 3
    • Gently remove the wires for the WLAN and WWAN cards from their housing.
  34. Dell XPS 17 L702X Motherboard Replacement: step 34, image 1 of 1
    • Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
  35. Dell XPS 17 L702X Motherboard Replacement: step 35, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 35, image 2 of 2
    • Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
    • DO NOT ATTEMPT TO REMOVE THE SCREW FROM THE WIRE. The screw is permanently fixed onto the wire.
  36. Dell XPS 17 L702X Motherboard Replacement: step 36, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 36, image 2 of 2
    • Using the plastic opening tool, detach the connection from the cable to the board.
  37. Dell XPS 17 L702X Motherboard Replacement: step 37, image 1 of 1
    • Gently remove the monitor cable from its holdings from the board.
  38. Dell XPS 17 L702X Motherboard Replacement: step 38, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 38, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 38, image 3 of 3
    • Hold the plastic edge of the display firmly and lift to remove the display.
  39. Dell XPS 17 L702X Motherboard Replacement, Motherboard: step 39, image 1 of 1
    • Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
  40. Dell XPS 17 L702X Motherboard Replacement: step 40, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 40, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 40, image 3 of 3
    • Locate the sound card cable.
    • Gently unplug the sound card cable.
  41. Dell XPS 17 L702X Motherboard Replacement: step 41, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 41, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 41, image 3 of 3
    • Find the orange cable with the letters MB.
    • Gently insert the spudger below the edge of the black tab and pry it open.
    • DO NOT attempt to pull out the cable on this step.
  42. Dell XPS 17 L702X Motherboard Replacement: step 42, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 42, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 42, image 3 of 3
    • Locate the wire on the side of WWAN slot.
    • Using the spudger, gently pull out the cable.
  43. Dell XPS 17 L702X Motherboard Replacement: step 43, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 43, image 2 of 2
    • Gently flip the laptop with its bottom facing you.
    • Remove the four 8mm screws with a Phillips screwdriver.
    • Remove the two 16mm battery casing screws with a Phillips screwdriver.
    • Remove the two 16mm corner screws with a Phillips screwdriver.
    • Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
    • Removing the RAM is optional. This guide does not cover the removal of the RAM card.
  44. Dell XPS 17 L702X Motherboard Replacement: step 44, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 44, image 2 of 2
    • Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
    Make sure you remember to remove the SD card cover before pulling off the back cover
    watercannons - Reply
  45. Dell XPS 17 L702X Motherboard Replacement: step 45, image 1 of 1
    • Unscrew the seven 4mm screws with a Phillips screwdriver.
  46. Dell XPS 17 L702X Motherboard Replacement: step 46, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 46, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 46, image 3 of 3
    • Unscrew the 6mm screw on the DC cable assembly with a Phillips screwdriver.
    • Lift the DC cable assembly out of the casing.
    • Gently unplug the DC cable.
  47. Dell XPS 17 L702X Motherboard Replacement: step 47, image 1 of 1
    • Lift and remove the Wi-Fi circuit board.
  48. Dell XPS 17 L702X Motherboard Replacement: step 48, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 48, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 48, image 3 of 3
    • Gently use a spudger to pry off the fan power cable.
    • Lift and remove the fan.
  49. Dell XPS 17 L702X Motherboard Replacement: step 49, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 49, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 49, image 3 of 3
    • Lift and remove the USB circuit board out of its housing.
    • Remove the orange cable from the motherboard by gently pulling away from the connection point.
  50. Dell XPS 17 L702X Motherboard Replacement: step 50, image 1 of 2 Dell XPS 17 L702X Motherboard Replacement: step 50, image 2 of 2
    • Loosen the six screws with a Phillips screwdriver.
    • The screws are attached to the heat sink piece. Do not attempt to remove them from the heat sink assembly.
  51. Dell XPS 17 L702X Motherboard Replacement: step 51, image 1 of 3 Dell XPS 17 L702X Motherboard Replacement: step 51, image 2 of 3 Dell XPS 17 L702X Motherboard Replacement: step 51, image 3 of 3
    • Gently lift and remove the motherboard.
    • Clean the thermal paste with rubbing alcohol and a microfiber cloth or non-abrasive tissue.
11 other people completed this guide.
Eddie
470 Reputation
2 Guides authored
CSU Fullerton, Team 2-6, Bruce Fall 2015 Member of CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Members
8 Guides authored
4 Comments
it really helped me out with my extremely fast overheating pc. and now it is mutch cooler and working great, Thanks!
Bjorn stevens - Reply
I wouldn’t rate this as extremely difficult though to be honest. I’d say moderate at best.
Clems - Reply
Great step by step guide with excellent photos helped me to reapply Thermal paste to my CPU/GPU heatsink.
Thank you!
Petros Lamprakis - Reply
Not difficult at all to dismantle this thing. I do it all the time for maintenance.
80s Guy - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 7,129
