Dell XPS 18 Wireless WLAN Card Replacement
  1. Dell XPS 18 Wireless WLAN Card Replacement, Back Cover: step 1, image 1 of 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Wireless WLAN Card Replacement: step 2, image 1 of 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Wireless WLAN Card Replacement: step 3, image 1 of 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Wireless WLAN Card Replacement, Internal Cover: step 4, image 1 of 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Wireless WLAN Card Replacement: step 5, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 5, image 2 of 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Wireless WLAN Card Replacement: step 6, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 6, image 2 of 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: step 7, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: step 7, image 2 of 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Wireless WLAN Card Replacement: step 8, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 8, image 2 of 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Wireless WLAN Card Replacement: step 9, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 9, image 2 of 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card Wires: step 10, image 1 of 1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Wireless WLAN Card Replacement: step 11, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 11, image 2 of 2
    • Pull back the cables.
  12. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card: step 12, image 1 of 1
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  13. Dell XPS 18 Wireless WLAN Card Replacement: step 13, image 1 of 2 Dell XPS 18 Wireless WLAN Card Replacement: step 13, image 2 of 2
    • Angle the wireless WLAN card upward and remove it.
2 other people completed this guide.
Austin Weir
1,287 Reputation
8 Guides authored
Cal Poly, Team 6-29, Amido Winter 2015 Member of Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,340
