Dell XPS M1330 Fan Replacement
  1. Dell XPS M1330 Fan Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Fan Replacement: step 2, image 1 of 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Fan Replacement: step 3, image 1 of 2 Dell XPS M1330 Fan Replacement: step 3, image 2 of 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Fan Replacement, Fan: step 4, image 1 of 2 Dell XPS M1330 Fan Replacement, Fan: step 4, image 2 of 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 Fan Replacement: step 5, image 1 of 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 Fan Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 Fan Replacement: step 7, image 1 of 1
    • Gently remove the fan and its attachments from the bay.
Kai Kapossy
676 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 377
