Dell XPS M1330 Keyboard Replacement
  1. Dell XPS M1330 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Keyboard Replacement: step 2, image 1 of 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Keyboard Replacement: step 3, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 3, image 2 of 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Keyboard Replacement, Hard Drive: step 4, image 1 of 1
  5. Dell XPS M1330 Keyboard Replacement: step 5, image 1 of 1
    • Remove the four 3.0mm Phillips #1 screws securing the hard drive casing.
  6. Dell XPS M1330 Keyboard Replacement: step 6, image 1 of 3 Dell XPS M1330 Keyboard Replacement: step 6, image 2 of 3 Dell XPS M1330 Keyboard Replacement: step 6, image 3 of 3
    • Slide the hard drive away from the computer, slowly and carefully.
  7. Dell XPS M1330 Keyboard Replacement, Fan: step 7, image 1 of 2 Dell XPS M1330 Keyboard Replacement, Fan: step 7, image 2 of 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  8. Dell XPS M1330 Keyboard Replacement: step 8, image 1 of 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  9. Dell XPS M1330 Keyboard Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  10. Dell XPS M1330 Keyboard Replacement: step 10, image 1 of 1
    • Gently remove the fan and its attachments from the bay.
  11. Dell XPS M1330 Keyboard Replacement, CPU: step 11, image 1 of 1
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  12. Dell XPS M1330 Keyboard Replacement: step 12, image 1 of 1
    • Using the iFixit opening tool, prop up the CPU.
  13. Dell XPS M1330 Keyboard Replacement: step 13, image 1 of 1
    • Carefully lift the CPU away from its housing.
  14. Dell XPS M1330 Keyboard Replacement, Keyboard: step 14, image 1 of 1
    • Unscrew the 5.0mm Phillips #1 screw from the wireless door cover.
    • Pull straight up on the wireless door.
  15. Dell XPS M1330 Keyboard Replacement: step 15, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 15, image 2 of 2
    • Unscrew the 3.0mm Phillips #1 screw from the wireless card.
  16. Dell XPS M1330 Keyboard Replacement: step 16, image 1 of 3 Dell XPS M1330 Keyboard Replacement: step 16, image 2 of 3 Dell XPS M1330 Keyboard Replacement: step 16, image 3 of 3
    • Slide the card to the left and up to remove it.
  17. Dell XPS M1330 Keyboard Replacement: step 17, image 1 of 3 Dell XPS M1330 Keyboard Replacement: step 17, image 2 of 3 Dell XPS M1330 Keyboard Replacement: step 17, image 3 of 3
    • Separate the two clips on both sides of the memory sticks.
    • The memory stick will lift up.
    • Gently pull the memory stick up and out of its holder.
    • Repeat these same steps for the second memory stick below.
  18. Dell XPS M1330 Keyboard Replacement: step 18, image 1 of 1
    • Remove the two 2.5mm Phillips #1 screws in the battery housing port.
  19. Dell XPS M1330 Keyboard Replacement: step 19, image 1 of 1
    • Flip the laptop back over so the cover is on top.
  20. Dell XPS M1330 Keyboard Replacement: step 20, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 20, image 2 of 2
    • Carefully open the screen, so it is facing toward yourself.
    • Flatten out the screen as much as possible.
  21. Dell XPS M1330 Keyboard Replacement: step 21, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 21, image 2 of 2
    • Carefully lift the computer, so you can get a good grip by the hinges.
    • Carefully lift and remove the central control media button cover from the base.
    • This piece snaps out of its constraints. Be slow and controlled, so you don't break a snap. There is also a cable attached underneath.
  22. Dell XPS M1330 Keyboard Replacement: step 22, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the two 3.0mm screws at the top of the keyboard.
  23. Dell XPS M1330 Keyboard Replacement: step 23, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 23, image 2 of 2
    • When removing this piece lift slowly as there is a cord underneath that connects to the keyboard.
    • Carefully lift the keyboard up and toward the front screen.
  24. Dell XPS M1330 Keyboard Replacement: step 24, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 24, image 2 of 2
    • Lift the keyboard latch toward yourself.
  25. Dell XPS M1330 Keyboard Replacement: step 25, image 1 of 2 Dell XPS M1330 Keyboard Replacement: step 25, image 2 of 2
    • Gently pull the keyboard cable away from your body.
    • Detach the keyboard cable.
Kai Kapossy
676 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 597
