Dell XPS M140 Screen Replacement
  1. Dell XPS M140 Screen Replacement, Battery: step 1, image 1 of 1
    • Turn over the laptop.
  2. Dell XPS M140 Screen Replacement: step 2, image 1 of 3 Dell XPS M140 Screen Replacement: step 2, image 2 of 3 Dell XPS M140 Screen Replacement: step 2, image 3 of 3
    • Open the slide lock and pull out the battery.
  3. Dell XPS M140 Screen Replacement, Screen: step 3, image 1 of 3 Dell XPS M140 Screen Replacement, Screen: step 3, image 2 of 3 Dell XPS M140 Screen Replacement, Screen: step 3, image 3 of 3
    • The plastic casing around the screen has a gray rubber circle, lining the perimeter of the casing.
    • Remove the casing by peeling them off. This will expose the screws underneath.
  4. Dell XPS M140 Screen Replacement: step 4, image 1 of 1
    • Unscrew the screws on the casing that you just exposed.
  5. Dell XPS M140 Screen Replacement: step 5, image 1 of 3 Dell XPS M140 Screen Replacement: step 5, image 2 of 3 Dell XPS M140 Screen Replacement: step 5, image 3 of 3
    • With care, pop off the plastic clips sourrounding the casing.
    • Run your hand, or a tool, around the perimeter, to remove the casing.
  6. Dell XPS M140 Screen Replacement: step 6, image 1 of 3 Dell XPS M140 Screen Replacement: step 6, image 2 of 3 Dell XPS M140 Screen Replacement: step 6, image 3 of 3
    • Once the casing is removed, more screws should be exposed.
    • Remove every screw.
  7. Dell XPS M140 Screen Replacement: step 7, image 1 of 3 Dell XPS M140 Screen Replacement: step 7, image 2 of 3 Dell XPS M140 Screen Replacement: step 7, image 3 of 3
    • Once all of the screws are removed, the screen should be loose.
    • Gently pick it up and place it face down onto the keyboard.
  8. Dell XPS M140 Screen Replacement: step 8, image 1 of 3 Dell XPS M140 Screen Replacement: step 8, image 2 of 3 Dell XPS M140 Screen Replacement: step 8, image 3 of 3
    • There should be two connections.
    • One with a blue looking handle, and one with clips.
    • To remove the connection with the clips, squeeze the two clips together and pull the ribbon cable.
    • To remove the connection with the blue handle, gently pull on the blue handle, it should come right off.
Travis Morazzini
207 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 453
