Dell inspiron 15 5502 Memory modules Replacement
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell inspiron 15 5502 Memory modules Replacement, Screws: step 2, image 1 of 1
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell inspiron 15 5502 Memory modules Replacement, Getting the base cover out: step 3, image 1 of 1
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: step 5, image 1 of 2 Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: step 5, image 2 of 2
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell inspiron 15 5502 Memory modules Replacement, Drain the power: step 6, image 1 of 1
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
  5. Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 1 of 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 2 of 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 3 of 3
    • Where I am talking about.
    • Lift the mylar to uncover the memory module.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  6. Dell inspiron 15 5502 Memory modules Replacement, Removing: step 8, image 1 of 1
    • Remove the memory module from the memory-module slot.
    • Store the Ram sticks safely in an anti-static bag.
Finish Line
Kind-hearted, spirited Man
1,052 Reputation
4 Guides authored
Android Alliance Member of Android Alliance
Community
88 Members
703 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 496
