Delphi MyFi XM2GO Motherboard Replacement
  1. Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: step 1, image 1 of 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: step 1, image 2 of 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: step 1, image 3 of 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Delphi MyFi XM2GO Motherboard Replacement, Battery: step 2, image 1 of 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: step 2, image 2 of 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: step 2, image 3 of 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Delphi MyFi XM2GO Motherboard Replacement, Motherboard: step 3, image 1 of 2 Delphi MyFi XM2GO Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Delphi MyFi XM2GO Motherboard Replacement: step 4, image 1 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 4, image 2 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 4, image 3 of 3
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Delphi MyFi XM2GO Motherboard Replacement: step 5, image 1 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 5, image 2 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 5, image 3 of 3
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Delphi MyFi XM2GO Motherboard Replacement: step 6, image 1 of 2 Delphi MyFi XM2GO Motherboard Replacement: step 6, image 2 of 2
    • Remove the back cover.
  7. Delphi MyFi XM2GO Motherboard Replacement: step 7, image 1 of 2 Delphi MyFi XM2GO Motherboard Replacement: step 7, image 2 of 2
    • Remove the power button by pulling it to the left.
  8. Delphi MyFi XM2GO Motherboard Replacement: step 8, image 1 of 2 Delphi MyFi XM2GO Motherboard Replacement: step 8, image 2 of 2
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Delphi MyFi XM2GO Motherboard Replacement: step 9, image 1 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 9, image 2 of 3 Delphi MyFi XM2GO Motherboard Replacement: step 9, image 3 of 3
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
Scott Byer
88 Reputation
5 Guides authored
Clemson, Team 1-2, Benson Spring 2012 Member of Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 2,669
