Delta Push Valve Shower Diverter RP5649 Replacement
  1. Delta Push Valve Shower Diverter RP5649 Replacement, Delta Push Valve Shower Diverter: step 1, image 1 of 1
    • Remove the decorative cap off of the knob by pushing a flathead screwdriver underneath the cap.
    • For this step, you can use anything that can get into the seam, such as metal spudger.
  2. Delta Push Valve Shower Diverter RP5649 Replacement: step 2, image 1 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 2, image 2 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 2, image 3 of 3
    • With a Phillips #2 screwdriver, remove the screw inside of the knob. Pull to remove the shower knob.
    • Keep track of this screw to ensure that it does not get lost.
  3. Delta Push Valve Shower Diverter RP5649 Replacement: step 3, image 1 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 3, image 2 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 3, image 3 of 3
    • Using a flathead screwdriver remove the two screws holding the faceplate in place.
    • Remember to mark where each screw went to avoid confusion when putting everything back together.
  4. Delta Push Valve Shower Diverter RP5649 Replacement: step 4, image 1 of 2 Delta Push Valve Shower Diverter RP5649 Replacement: step 4, image 2 of 2
    • Use the 3/8 in. Drive 7/8 in. 6-Point SAE deep socket to remove the old diverter. Place the deep socket over the diverter and unscrew.
    • If the diverter does not come loose with just the deep socket, you can attach a ratcheting wrench to unscrew it.
  5. Delta Push Valve Shower Diverter RP5649 Replacement: step 5, image 1 of 2 Delta Push Valve Shower Diverter RP5649 Replacement: step 5, image 2 of 2
    • Insert the new diverter in place of the old one. Tighten with the deep socket or wrench.
    • Make sure the diverter is on tight! Water will leak out from the diverter if it is not tightened properly.
  6. Delta Push Valve Shower Diverter RP5649 Replacement: step 6, image 1 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 6, image 2 of 3 Delta Push Valve Shower Diverter RP5649 Replacement: step 6, image 3 of 3
    • Reassemble the faceplate and knob. Remember to place the screws back in the places they were originally.
    • You will want to make sure the screws are properly lined up before screwing them into the face plate. Without lining them up, they will not tighten and the face plate will fall off. If this happens, push the screws in until you feel a slight click into place, then screw them back in.
Test the water flow before leaving the project! If it is leaking, you may need to tighten the diverter or screws.
Once everything looks good, you’re done! Great job. You’ve saved yourself a visit from the plumber by fixing it yourself.
3 other people completed this guide.
Rosemary DaCruz
205 Reputation
1 Guide authored
Marist, Team S2-G1, Chaterdon Spring 2021 Member of Marist, Team S2-G1, Chaterdon Spring 2021
MARS-CHATERDON-S21S2G1
2 Members
1 Guide authored
One Comment
Please turn on the water and engage the diverter. I want to see it work! I put in a new diverter and it did not completely divert ALL of the water. After installing the new diverter, about 10% - or so - of the water continued to come out of the faucet (and 90% was diverted up to the shower head). I'm not sure how to fix this problem. Perhaps, I will let a little water to flow out of the faucet, wasting water and electricity (to heat the water).
John Stensby - Reply
Past 24 Hours: 13
Past 7 Days: 84
Past 30 Days: 374
All Time: 14,709
