Desktop PC Hard Drive Replacement
  1. Desktop PC Hard Drive Replacement, Left Panel: step 1, image 1 of 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Hard Drive Replacement: step 2, image 1 of 2 Desktop PC Hard Drive Replacement: step 2, image 2 of 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Hard Drive Replacement, Right Panel: step 3, image 1 of 1
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
  4. Desktop PC Hard Drive Replacement: step 4, image 1 of 2 Desktop PC Hard Drive Replacement: step 4, image 2 of 2
  5. Desktop PC Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
  6. Desktop PC Hard Drive Replacement: step 6, image 1 of 1
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
  7. Desktop PC Hard Drive Replacement: step 7, image 1 of 1
    • Slide the hard drive out from the metal casing.
  8. Desktop PC Hard Drive Replacement: step 8, image 1 of 1
    • Remove the cables from the back of the hard drive.
62 other people completed this guide.
Rubin Girling
748 Reputation
1 Guide authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
45 Guides authored
2 Guide Comments
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - Reply
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - Reply
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 192
All Time: 11,220
