Deutz Brake Cylindern Disassembly
  1. Deutz Brake Cylindern Disassembly, Overveiw: step 1, image 1 of 2 Deutz Brake Cylindern Disassembly, Overveiw: step 1, image 2 of 2
    • Here is all the parts removed so you have an ide of what is to come.
  2. Deutz Brake Cylindern Disassembly: step 2, image 1 of 2 Deutz Brake Cylindern Disassembly: step 2, image 2 of 2
    • This is the cylinders placement on the center housing.
  3. Deutz Brake Cylindern Disassembly: step 3, image 1 of 2 Deutz Brake Cylindern Disassembly: step 3, image 2 of 2
    • First we will remove the adjuster bolt, untighten the nut with 17mm spanner and then unscrew the bolt with a 8mm spanner.
  4. Deutz Brake Cylindern Disassembly: step 4, image 1 of 2 Deutz Brake Cylindern Disassembly: step 4, image 2 of 2
    • Next remove the locking ring with lock ring pliers.
    • Flip the cylinder over.
  5. Deutz Brake Cylindern Disassembly: step 5, image 1 of 1
    • Remove this bigger lock ring taking care since the spring is under some tension.
  6. Deutz Brake Cylindern Disassembly: step 6, image 1 of 3 Deutz Brake Cylindern Disassembly: step 6, image 2 of 3 Deutz Brake Cylindern Disassembly: step 6, image 3 of 3
    • If your cylinder is in good condition you might be able to get the piston out with compressed air but mine is rusted in place.
    • So I used a greasegun and some special fittings. A brake pipe fitting threaded for a grease nipple.
    • Replace the air bleed nipple with the greasegun nipple.
  7. Deutz Brake Cylindern Disassembly: step 7, image 1 of 3 Deutz Brake Cylindern Disassembly: step 7, image 2 of 3 Deutz Brake Cylindern Disassembly: step 7, image 3 of 3
    • Plug the hydraulic inlet and use the greasegun to force the parts out.
    • First comes the plunger that in this case was rusted in place.
    • Next the piston.
  8. Deutz Brake Cylindern Disassembly: step 8, image 1 of 3 Deutz Brake Cylindern Disassembly: step 8, image 2 of 3 Deutz Brake Cylindern Disassembly: step 8, image 3 of 3
    • Next turn it over and use a 17mm spanner to remove the hand brake arm bolt.
    • Then using a scribe mark the end positions for the arm so you can get it back in the right rotation. Both the arm and the inner pusher have splines so this is a good thing to do.
  9. Deutz Brake Cylindern Disassembly: step 9, image 1 of 1
    • Remove the arm and flip it top side upp.
  10. Deutz Brake Cylindern Disassembly: step 10, image 1 of 3 Deutz Brake Cylindern Disassembly: step 10, image 2 of 3 Deutz Brake Cylindern Disassembly: step 10, image 3 of 3
    • The handbrake axle is locked by a small pin marked with the red arrow. I used a welder and a slidehammer to remove this.
  11. Deutz Brake Cylindern Disassembly: step 11, image 1 of 3 Deutz Brake Cylindern Disassembly: step 11, image 2 of 3 Deutz Brake Cylindern Disassembly: step 11, image 3 of 3
    • Next use the slidehammer and a m10 threaded end to remove the habdbrake axle like in picture 2.
  12. Deutz Brake Cylindern Disassembly: step 12, image 1 of 2 Deutz Brake Cylindern Disassembly: step 12, image 2 of 2
    • Remove the screw that stops the adjuster parts from rotating.
  13. Deutz Brake Cylindern Disassembly: step 13, image 1 of 3 Deutz Brake Cylindern Disassembly: step 13, image 2 of 3 Deutz Brake Cylindern Disassembly: step 13, image 3 of 3
    • Now we will have to separate these two parts to get the handbrake actuator out.
    • Using a m10 bolt and a metric pipe thread I forced the to rotate in different directions which broke them free,
  14. Deutz Brake Cylindern Disassembly: step 14, image 1 of 3 Deutz Brake Cylindern Disassembly: step 14, image 2 of 3 Deutz Brake Cylindern Disassembly: step 14, image 3 of 3
    • Now the top part can be removes followed by the handbrake actuator and lastly the lower part.
Hans
400 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 50
All Time: 164
