Dewalt DCD778 Clutch Replacement
  1. Dewalt DCD778 Clutch  Replacement, Battery: step 1, image 1 of 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Clutch  Replacement: step 2, image 1 of 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Clutch  Replacement: step 3, image 1 of 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Clutch  Replacement, Clutch: step 4, image 1 of 2 Dewalt DCD778 Clutch  Replacement, Clutch: step 4, image 2 of 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Clutch  Replacement: step 5, image 1 of 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Clutch  Replacement: step 6, image 1 of 1
    • Lift drill mechanism from the drill assembly.
  7. Dewalt DCD778 Clutch  Replacement: step 7, image 1 of 3 Dewalt DCD778 Clutch  Replacement: step 7, image 2 of 3 Dewalt DCD778 Clutch  Replacement: step 7, image 3 of 3
    • Twist slightly and pull clutch away from motor.
    • Remove clutch.
Brittany
705 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 62
All Time: 3,585
