Dewalt DCD778 Forward/Reverse Switch Replacement
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: step 1, image 1 of 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 2, image 1 of 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 3, image 1 of 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: step 4, image 1 of 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 5, image 1 of 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 6, image 1 of 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 7, image 1 of 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Brittany
705 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 48
All Time: 2,367
