Dewalt DCD778 Motor Replacement
  1. Dewalt DCD778 Motor Replacement, Battery: step 1, image 1 of 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Motor Replacement: step 2, image 1 of 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Motor Replacement: step 3, image 1 of 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Motor Replacement, Motor: step 4, image 1 of 2 Dewalt DCD778 Motor Replacement, Motor: step 4, image 2 of 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Motor Replacement: step 5, image 1 of 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Motor Replacement: step 6, image 1 of 1
    • Lift the drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
  7. Dewalt DCD778 Motor Replacement: step 7, image 1 of 2 Dewalt DCD778 Motor Replacement: step 7, image 2 of 2
    • Slightly twist and pull motor away from the clutch.
  8. Dewalt DCD778 Motor Replacement: step 8, image 1 of 1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
2 other people completed this guide.
Brittany
693 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 52
All Time: 1,483
