Dewalt DCF885 Motor Assembly Replacement
  1. Dewalt DCF885 Motor Assembly Replacement, Battery: step 1, image 1 of 1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Motor Assembly Replacement: step 2, image 1 of 1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Motor Assembly Replacement, Motor Assembly: step 3, image 1 of 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Motor Assembly Replacement: step 4, image 1 of 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Motor Assembly Replacement: step 5, image 1 of 1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Motor Assembly Replacement: step 6, image 1 of 1
    • Pull the motor away from the brush assembly.
One Comment
That's not the motor assembly. That's the Gearbox. The motor and brush assembly are together in the rear of the drill.
John B - Reply
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 60
All Time: 2,893
