Dexcom G6 Receiver Charging Port Replacement
  1. Dexcom G6 Receiver Charging Port Replacement, Display and Front Bezel: step 1, image 1 of 1
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Charging Port Replacement: step 2, image 1 of 2 Dexcom G6 Receiver Charging Port Replacement: step 2, image 2 of 2
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Charging Port Replacement, Charging Port: step 3, image 1 of 1
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Charging Port Replacement: step 4, image 1 of 1
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Charging Port Replacement: step 5, image 1 of 1
    • Remove the Charging Port Assembly from the motherboard.
Andrew S
15,047 Reputation
8 Guides authored
5 Comments
Where can the part be purchased?
Mayor of Koala Corner - Reply
I'm not sure if there is a replacement charging port assembly available online. If you're good at microsoldering, you could replace the surface mount micro USB port on the assembly.
Andrew S -
where can the part be purchased?
would a cell phone repair shop be able to do this?
Ron Magliacane - Reply
If they are comfortable with it. Tell them it will probably require microsoldering.
Andrew S -
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 696
