Dexcom G6 Receiver Motherboard Replacement
  1. Dexcom G6 Receiver Motherboard Replacement, Display and Front Bezel: step 1, image 1 of 1
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Motherboard Replacement: step 2, image 1 of 2 Dexcom G6 Receiver Motherboard Replacement: step 2, image 2 of 2
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Motherboard Replacement, Charging Port: step 3, image 1 of 1
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Motherboard Replacement: step 4, image 1 of 1
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Motherboard Replacement: step 5, image 1 of 1
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Motherboard Replacement: step 7, image 1 of 2 Dexcom G6 Receiver Motherboard Replacement: step 7, image 2 of 2
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Motherboard Replacement: step 8, image 1 of 1
    • Using a spudger, carefully pry up the motherboard to remove it.
Andrew S
15,047 Reputation
8 Guides authored
2 Comments
do you know of anyone that can fix these items
Rick MacDonald - Reply
anyone out there fix these items
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 771
