Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement
  1. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 2, image 1 of 2 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 2, image 2 of 2
    • Unscrew the four screws from the tray.
    • Then the four screws inside the tray.
  3. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 3, image 1 of 2 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 3, image 2 of 2
    • Unscrew the screws of the shell to open the machine.
  4. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 4, image 1 of 2 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 4, image 2 of 2
    • Remove the orange switch cap for more space.
    • Use pliers to disconnect the wires from the switch. Press the tab to extract it.
  5. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 6, image 1 of 3 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 6, image 2 of 3 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 6, image 3 of 3
    • Replace the new switch, then reconnect the wires.
    • Replace the sheath, then check that no cable is blocked and that each part is in its housing.
  6. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 7, image 1 of 1
    • Replace the orange cap.
  7. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 8, image 1 of 1
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Replace the shell and screws.
  8. Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 9, image 1 of 2 Dexter 200W Corded Orbital Sander - 200SHS2.5 Switch Replacement: step 9, image 2 of 2
    • Replace the four screws located inside.
    • Then the screws of the plate.
To reassemble perform steps in reverse.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 225
