Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement
  1. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement, Unplug: step 1, image 1 of 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 2, image 1 of 1
    • Remove the seal on the back of the device.
  3. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 3, image 1 of 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 3, image 2 of 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 3, image 3 of 3
    • Unscrew the first screw from the pad.
    • Then unscrew the remaining four screws and pull up to remove it.
    • Finally, remove the screws located on the shell of the device.
    • To remove the stabilisers you must leverage with a screwdriver.
    • To reset the new stabiliser, you just have to reposition it in your home.
  4. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 6, image 1 of 2 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 6, image 2 of 2
    • Replace the hull of the sander, taking care to properly position the stabilisers in their housings.
  5. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 7, image 1 of 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 7, image 2 of 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: step 7, image 3 of 3
    • Replace the pad by positioning it perfectly in the tips.
    • Screw the four screws
    • Then the last screw. Finally, put the joint back in its place.
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,608 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
37 Members
239 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 250
